Hello,
I've gotten a new computer, Mac Studio M2 Max and started up with Time Machine from my Macbook Pro on which I'm running Resolume on Sonoma 14.2.
Somehow managed to have a newer OS which I didn't want and so I had to retrograde to Sonoma 14.7.6 as I had some issues and wanted to have the same OS on both computers. Before retrograding it seemed that Resolume was working fine even though I just opened it to check.
But then Resolume asked me to update it, which I did inadvertently. Now I didn't understand it meant upgrading as well so I reverted to Resolume 7.6 (I think, 2021 version). But now it won't open anymore, just showing a message asking if I want to reopen... I tried rebooting to no avail.
Can I still use Resolume on that computer? The whole point of the new machine was to have more power for Resolume, but if I have to upgrade as well even though I'm using the same OS version, it's weird...
Mac Studio M2 max Sonoma 14.7.6
Re: Mac Studio M2 max Sonoma 14.7.6
Problem solved, I manage to re-install Resolume 7.6.0 and now everything runs perfectly it seems...
Indeed, thanks that worked out!
However, I have another issue now with DXV not being accepted with Aftereffect 2025 on Sonoma, M2 Max computer... on another thread here https://www.resolume.com/forum/viewtopi ... 75#p103175
