Resolume Decks Limit
Diogofx
Post by Diogofx »
Hello Community,
Been VJING for a while with my Macbook Pro M3 Pro, without any problem, (works like a charm :D ) and im wondering if resolume decks can handle, more and more clips on decks.
Im adding a lot of clips to decks, because i just simply like to have quick access to all my clips, and music can change, and we have those specific videos we like to put according to the music.
Does resolume decks have maximum capacity of clips, or is this related to your computer specs ?
Also, i usually get 119 fps when using 1 output, but when i use 2 different output, i get around 70 and 80 fps, which is pretty acceptable, and i think this is normal right?
Thank you so much!
Re: Resolume Decks Limit
Hey there,
as far as I know there is no clip limit.
I am also a "only one deck with everything"-person. My actual main show-deck usually contains around 2500 Clips.
hope that helps.
best wishes
Diogofx
Post by Diogofx »
Thanks Cosmowe for the answer!
