New Wire Pack! Wire Toolkit V.1
motus lumina
Post by motus lumina »
Wire Toolkit V.1 by Motus Lumina
A generative pack made with the Resolume Wire node-based programming environment. Wire Toolkit V.1 contains procedural textures, light generators, fluid generators, and feedback-based abstract visual compositions. You can create endless variations by using the built-in parameters.
30 Wire Patches + Cwired Patches
*Works on both PC and Mac operating systems.
https://www.luminaspace.com/wire-toolkit-v1
ataberkycl
Re: New Wire Pack! Wire Toolkit V.1
Post by ataberkycl »
Bought this and really enjoy using it in realtime shows.
MarkyMark
Post by MarkyMark »
Nice one! I'm glad to see you enjoying Wire.
motus lumina
ataberkycl wrote: Mon Jun 16, 2025 20:20 Bought this and really enjoy using it in realtime shows.
Thank you so much for your purchase.
I am looking forward to releasing the Wire Toolkit V. 2
motus lumina
MarkyMark wrote: Thu Jun 19, 2025 16:26 Nice one! I'm glad to see you enjoying Wire.
Thank you very much for your comment Mark.
Wire Toolkit V.2 is on the way.
