Advanced output toggle?
adamseeley
Post by adamseeley »
Is there a way to toggle outputs to be on/off with a shortcut (rather than going into the Advanced setup each time)?
i.e.
I have a small two screen show coming up and am using my two extra Left & Right monitors as outputs to try out some stuff at home.
If I want to preview the outputs and make them 'live' I have to go into the Advanced Output screen and then save & close.
i.e. CTRL + SHIFT + A
To stop the outputs to the monitors (so I can see my desktops etc again) I disable the outputs
i.e. CTRL + SHIFT + D
Ideally I'd just like to be able to toggle the displays on/off without going into the Advanced Output page each time.
Possible?
Thanks, Adam.
luver88
Re: Advanced output toggle?
Post by luver88 »
Hopefully, this gets considered in a future update would be a handy quality-of-life feature.
________________________________
Mixing beats & betting slips on cz-mostbet since 2020
applaudearn
Post by applaudearn »
Resolume's current functionality doesn't have a direct "enable/disable all outputs" shortcut that bypasses the Advanced Output screen entirely. If you still want to do this, you can toggle each slice/screen individually (via shortcut mapping)
