We have a permanent installation that makes use of the Magewell USB Capture HDMI 4K Plus with Resolume Avenue to provide live video input from other source devices like a laptop.
The system is using the latest Avenue with the latest Mac OS and is on a Mac Studio with Resolume feeding signal into MadMapper over Syphon.
We have been experiencing issues with the reliability of this setup and would like to explore potential solutions.
The main issue is that the link between the Magewell and Avenue "decays" after an arbitrary amount of time or system restarts.
We will get it working great, for months at a time, and then for whatever reason the next time it is opened the Live Input is no longer working. It is just blank and most notably the resolution setting is missing for the Live Input in the clip settings. We can confirm no changes to the file have been made as it all automatically loads and starts at system boot.
The initial work around was to instruct the client to drag a new instance of the USB Capture from the Source panel onto the previously working clip itself and then manually select the correct resolution.
This has been work around has been suitable for some months but now it is no longer working either.
We have also tried clearing/deleting the Live Input clip and then dragging in a new fresh one and that does not seem to be working either.
We are currently trying every combination of restarting, unplugging, replugging, and nothing seems to be working anymore.
We can confirm that the Magewell capture device is functional and that it can be picked up by the Magewell Capture Utility. The status lights are on, the source computer recognizes it is being plugged in, etc.
Here are some specific questions:
1) Is this a known issue between Magewell devices and Resolume Avenue?
2) Are there better capture cards available that are known to work 100% with Resolume Avenue?
3) Would another program, such as MadMapper (even though not using the Magewell at all), conflict with Resolume Avenue trying to read from it?
4) Are there other troubleshooting steps we can perform in order to diagnose the issue and fix it?
Thank you for any input on this subject.
Help with Magewell USB Capture HDMI 4K Plus in Resolume Avenue
Lumenarius
Lumenarius
Re: Help with Magewell USB Capture HDMI 4K Plus in Resolume Avenue
If anyone other than the above bot has anything to add that would be very valuable. Thanks!
Lumenarius
After much troubleshooting the only solution we have been able to find is to manually unplug the Magewell unit, plug it back in, and then rebuild the Resolume file from scratch.
This is of course a lot of friction and for a $500 HDMI capture device and the world's best VJ software we will continue to look for a better solution so our client does not have to manually do this ever 24-48 hours indefinitely.
If anyone has direct experience with these HDMI capture cards inside of Resolume, including alternative models, that would be great to learn about.
I don't know exactly what your installation should do...
So therefore I don't know if my suggestion is suitable for you or not.
Did you think about getting rid of the HDMI capture card and trying to achieve it with an NDI input instead?
Bring the devices into the same network, install NDI Tools on the laptop,
set up Screen Capture (incl. autostart capture),
and add the NDI source into your composition.
And sorry, I don't have another suggestion for your Avenue/Magewell situation. I own two older Magewell HDMI dongles from the first generation, and they're still working fine. I have to admit, I haven't used them in a permanent installation.
Best wishes
cosmowe.
Best wishes
cosmowe.
Do you like outlines? Easy Outliner on Juicebar -
Lumenarius
Hi Cosmowe,
Thank you for the thoughtful reply. Troubleshooting is the nature of this realm and it's good to know you have had success with these devices in general in the past.
NDI input is definitely something I am considering recommending though it does add a little bit of complexity to the setup. Also, in my experience, there can be a little bit of lag with NDI though it may be negligible and ultimately I need to do more testing to be sure.
Okay after doing some testing...
I think that the NDI approach is actually more robust. Especially as it can capture windows on the host computer.
More testing will be necessary at scale to ensure reliability and performance.
Ultimately as long as the NDI source does not decay or disappear such that the show file needs to be amended each time we are good to go.
Are you changing which USB the capture card is connected before it breaks?
Lumenarius
Thank for the reply Zoltan.
I can confirm that no cables are being unplugged or re-plugged to trigger this issue. It's all in a server rack and the client never reaches in to change anything. There is also no USB hub in the way it's direct to the computer using the OEM USB C cable.
The only thing I can think of currently is that maybe it's static electricity?
We're exploring a few other solutions like NDI but that just means more client training and it would be great to see this Magewell device run stable as it used to in our testing lab.
When I get back to the office I am going to try 100 ish power cycles of a similar system we have and see if I can get it to trip up on my own.
I can also confirm no issue I had with magwell hdmi capture 4k, I have set up in a one year installation with ledwall, resolume capture a laptop from magwell (power point mostly) and having a background, the client start the pc and find everything as the last time.
When I have used the same card live no problems also, the only issue I have in mind since I have macbook pro with only usb-c port, I have bought a usb-c usb-a cable and it didn’t work (as I read in magwell manual, while its sees the card with resolume wasn’t stable at all, they need their blue cable, i mean the one which came in the box (or similar) and then connected with hub o usb-c usb-a adapter.
I have no feedback for a permanent installation with elgato capture card, only with show and festival four day at max and i didn’t have any issue (used for acquiring camera to send to imag)
Lumenarius
Thank you for the reality check Vejas this is super helpful to know that there are other installations using nearly the same setup and it has been stable.
I am going to confirm with the client about the USB cable compatibility. One thing is that the OEM blue cable that comes with Magewell is USB A into the computer whereas I think we used the included Magewell OEM USB A to C converter. I don't think that is the issue though as it has also shown this issue on a PC (currently on Mac Studio) and we did not use that adapter.
Other potential avenues we are exploring are the possibility of an actual bug and also the possibility this is all due to excess static electricity.
As a recap the things that have fixed this problem for us, though not a permanent solution are as follows:
1) Unplug everything, re boot, replug, rebuild Avenue Show File. Not ideal but does work until about 24-48 hours from then in which this needs to be done again.
2) Use NDI input. This does not carry the sound well, introduces a bit more lag, and of course makes setup of the source computer more difficult as IP settings need to be arranged.
The whole point of this is for when our client has a meeting in this dome they need to be able to simply plug and play another laptop into this system with an HDMI cable and just have it display this with one click on the column for that setup.
I am confident we will find a solution to this and I will be sure to post it in this thread when we do.
We're looking into capture cards resetting their resolutions.
However cards going completely offline, we've have not seen yet.
Does the client restart their computer at all, or do they leave it go to sleep at the end of a work day?
