Feature Request: Media Library Path and similar...
seethings
Post by seethings »
I think it would be very helpful to provide in the preferences section a place to choose where your Main Media Library is. Media Library Path.
This would be helpful for those who need to offload their content to external drives and back. It would speed up process of rematching media files up with the compositions.
And while at it, please provide ability to add user defined locations of Resolume Arena and Resolume Wire folders that exist in the Documents folder.
Since Sequoia, the path to the Documents folder is changed if you use Sync Documents folder to iCloud. i.e. /Users/username/Library/Mobile Documents/com~apple~CloudDocs/Documents/Resolume Wire. Prior to Sequoia, it would be here: /Users/username/Documents/Resolume Wire
-Seethings (Tim Furnish)
Re: Feature Request: Media Library Path and similar...
As long as you keep the folder structure when moving your library, the reconnect should be a one step process.
