fps dropping DRASTICALLY with the second A5000
VjLuper
Post by VjLuper »
Hello beautiful people!
I have a high-performance PC with two NVIDIA RTX A5000. I use the first DisplayPort for my main monitor, and the remaining 7 outputs for 4K projectors.
When I use the three DisplayPorts on the same card as the main monitor, everything runs smoothly at 60 FPS.
But as soon as I start using the DisplayPorts on the second card, performance drops—by about 15–20 FPS for each additional output. With all 4 ports on the second card active, FPS drops to 10–15.
Is there something I should know about using multiple GPUs with Resolume?
Empyfree
Re: fps dropping DRASTICALLY with the second A5000
Post by Empyfree »
There’s some info here about why adding a second GPU causes performance hits. https://resolume.com/support/en/lots-of ... h-two-gpus
