Strip effects
Acidvideo
Strip effects
Post by Acidvideo »
For me it could be very handy if there would be an option to strip effects from a selection of clips.
For example if i want to reuse a comp and every clip has a transform effect because at the previous gig i repositioned a lot of clips for the screens they had there, and i want to get rid of all of those transform effects when i start at the next gig and i don't want to have to remove all transform effects one by one manually. Sometimes this can be a lot of clips
cat
Re: Strip effects
Post by cat »
I use groups and layers to do things like that (if its not worth slicing) so rather every clip having a transform, its just the group or layer, would that work for you?
