Osc Message between 2 patch
Timoxy
Post by Timoxy »
Hi all,
it's me again.
I need to use 2 timer for different screen, so i want a master and slave timer. the master send the time on the slave timer.
Why ? because i'll use the scoring board to put on big led wall, but sometimes i need to change the content (video, picture or other) so, when i change the clip, the timer stop. So it's for that i want a master timer to send by OSC the real time in continue. Problem. i use OSC message between 2 patch (master and slave) On wire all works fine, the timer start great, pause, en restart, and go to 00:00. but on resolume i've nothing, the timer don't change. i control my patches in resolume and i've wire input to see message, when i start my master timer on resolume, wire see osc message and the timer move but not in resolume .... you know why ?
Re: Osc Message between 2 patch
If you put your sender patch onto the composition as effect, it would play on composition load and won't stop till composition close.
You can also have multiple clips playing on separate layers, maybe you can play your content above your counter clip?
