We have a main machine that sends column triggers (only column triggers) to another Resolume machine, means all OSC output commands are disabled rather than column triggeres.
That works great and indeed every column trigger on the first machine fires the correlated column on the other.
UNTIL, you need to restart Arena on the main machine:
When main Arena restarts it sends some hidden OSC command (that no one asked it to) that changes the composition dimension and clips scale.
The only way to eliminate this behavior is to *manually* disable OSC in on the other machine until main Arena re-loads, forcing the second machine to 'not listen' while first one loading.
We had this issue before with a Mac Studio as the first machine and Windows based on the other, after some back and forth with the support we got to an understanding it is an issue with texture size mismatch between both machines.
Replacing main machine was the thing to do, or so we though.
Now both are windows based, both with same display adaptor (RTX 6000 ada) but the not wanted scaling is still here.
Any one experienced similar issues?
It would have been nice to be able to toggle OSC in/out via REST API/ midi or even a keystroke shortcut. GUI is just not fast enough for live show.
OSC output act weird on arena reload re-scaling targeted comp
Hakol.Sound
Re: OSC output act weird on arena reload re-scaling targeted comp
Hakol.Sound
Thanks but this has nothing to do with backup what so ever.
Anothertom
If you read through that thread, it's exactly the same thing you're asking about. When arena starts up it initialises and sends various OSC messages as part of that. It then loads the previous composition and any OSC settings/preferences. Which is also explained in that thread.Hakol.Sound wrote: Tue Aug 12, 2025 16:40 Thanks but this has nothing to do with backup what so ever.
It would make sense that arena would check the osc output settings (i.e. the selected OSC output preset and what messages are enabled) before sending those initialisation messages, but that doesn't currently happen.
If you're using hardware (midi, osc, dmx) then you can distribute those to both machines simultaneously, rather than using the OSC output to control the backup machine.
