Trigger one shots on specific beats
cat
Post by cat »
I want to trigger different parts of the patch on different beats, on change give a pulse on and off, I'm looking for a 'togedge' from vvvv, so only trigger on the front edge of a True. Any clues?
Ok this does it.
Re: Trigger one shots on specific beats
The Transport beat node outputs are numbers ;)
cat
Post by cat »
Still looking for a toggle edge to stop double counts of On change nodes
cat
Post by cat »
sort of a solution for tog edge
--begin-wire-patch--
1288.3ocyXszaiaCD9uxBc1xfuejawOBvBTr6kh1CEAEzVz1rUVxUhJ6lcQ9u2gT1VxNNJNcef5CVTiFNjy78wYFoulrrrnvtz6JKpSt4O9Zxppxsv.FYTRYieWiGkb+nDeYPFcThqnUzSi5TkdAU4vfJ2501pS0keAckWzr3KsEvuzdPdIcI8z898i+XUFrmt4qIqqJa1UGFgkbgDooHrhyCBVtwkmUYK.i.SaYYdtYWsMK4lUl7Z6njByVaxMIyLU9IklprjmF0YDhPPeiFoN4IvBUkk9VLHt0Rt4DSFb1ykG1uOAggjsVuIrllF+lRv6RRfUz3sqKqdDtqtroZoEjkY2kW93Vag+WMUqs9vbVTYJVtocN62S+tqJn8C1pZfWDTZq4uB1EhxacEgQDH1ty3CSDE17Y15kUtc9n9ASk4p2kad7Ccd46ZiU.NjAa.2JW.GRPRikgxroXDcYJShwoJlQlxVtXwhrrrUqLLXN4tk1hZ6ctbaq82KXu8AAaMt71Qk.wyUXx+l8Q5QeDG7w+owj67P.kRTbA.X15x7F+9ouw5VuAVMR3Qexk4CSiSEvDqMOX+duY7aZ1tn3nO2TsevC1hrVJ.nTg8y9OTlYeOP6vLFH.tokyyHQBiGNktnw2JLytxzj6+MSdiM0+3NaPX601Kf4COCtsnIOOrBqxK+TOsh21okE1M9fZsGCeEa5J.FKPJh5W6gnT61Zu1Gd7wIDiCKJaJxp6C.b4XMSqYRJWhkRIkQUcHhFx.8Y3JRPGSwXAiyQREl.hAjUKDiUBphh3BACIHbXIVlapiqfCBiIRoPKIBdJ5Vfqxlq4oZthAilNGIQpIJJqOVRhVnb4eCy8Af5WlDyFDwnUvOgAghhhtrucgZyZMfuGOzswkkESvbAjazArnenuef89iru2CXTOB0e9fq1sHbNyW0XCo1XzmyU9YhnD8XASoPZFknUTpVE3xOCQ47wDBmq3ZprENwHIdLlwwLr.g4CBmyESHoLMAmpu6NV5zIzaQ2JUvSm8SGNecL6iEua5FSwZ6fH2kNjO7I1Z2ZHyYuirYNnbQca6ACAbW4YbX4LcYDvuUyiuNyeQVjh7bNiPMlg3Lh.Q3Tc379ddiBOlxPHkToGNK.XBnX0bFK816lMIEJVOgLetlJlP6SaveOnMsdWORygnxKqSJZrVih+zPwHIihEmx0NMMQO734oNNGwNET5Hm+hstdXd4+0DJKJKy+VylPQOiGvv3wZLUH3RIloXc4OvZfGHgpEZJMlW4+GIPhwgiNZrixePYP3WBotpf+wNxSuxlDf9or9qUYXKT8ZJ2kLq1a2c0Ju+EWttcxEoX3KvwDLn0BMkAoF3DZOJFBZDIzQOlpf+TCQwlNSMER1HDoJAhBIav3YLAARQM8akhEC98O3s+s2N5vgN9ND2GNmTHX+xZf6hvu5xcFk9.s6Ll0ILmSXF8A9yv0tCBSA3yGW5ANFHeqEROu022bgtqeB0tuXGRm.cH7LzUTVNHG+cq9JvRCseALTkhz0jsDX7LNhhkzVwCzj8LNOko3ySUX5rTIRLaFe1cyUpY+nKuRuhxqj2VszypdFAtCXygXeGwblK3JCvKg0twE+VCvDpheA.HnmR4P0LNztaHIAO11aLtyUPFHJg.8yy4LnuEP7WJCe+DzXIi.05DbJk.3RDQps4seXnfmwBcy.sSFqHDOOz9dAihuI48O8z+BB2krIA
--end-wire-patch--
there is a Modulo node which could be useful with an Equal after
cat
Post by cat »
Ah, I’d not seen the if with a true false, that should help
