I'm working on a show with main and BU, previously I could just copy wire fx from one machine to another, overwrite updated ones, on which ever machine I hadnt been working on, they would instantly update and all was good. Now moving a FX from one PC to another, if you simple put them in the wire folder, they show as missing in arena, don't show in the FX/sources windows. You can open them in wire and save them, and they then show in the windows, but still are red/missing in the composition, and you have to manually replace them in the composition. This is very broken, and makes running a BU, difficult. To me this is a breaking change, when did it start happening, and can I roll back a version, and the fx/composition still work in the previous versions?
This may only happen in one direction, as pulling things back its ok, mid rehearsals so not an ideal bug fixing time..
Also missing slices, until I opened and then saved the advanced output window, the output was active, and as soon as I opened it, the slices appeared in arena, but if I didnt save, they disappear as soon as closing not saving.
Changes in moving wire fx to different pc
Re: Changes in moving wire fx to different pc
Are you copying them to /Documents/Resolume Wire/Patches?
Yes. I think it would be good to specify a 2nd folder that can be in a media folder though, and that collect media should copy all wire fx to that folder too… I’ve also dragged fx /sources to arena and ‘installed them as pop up, and they’ve appeared as patchname(1) when there has been no other versions there and I’ve no idea why the (1) has bee been added in arena.
Can you send us the Resolume log file from the feedback tab in preferences?
