Appending Slices to an existing Slice Transform
vjandrea
Post by vjandrea »
Hello team,
currently, when I drop a slice from the Advanced Output onto a clip, it creates a Slice Transform effect. If I then drop a second slice onto the same clip, it creates a new, separate instance of the Slice Transform effect.
I would like to propose that, when a clip already has one or more Slice Transform effects, dropping a new slice onto it would append that new slice to the last Slice Transform effect in the chain, rather than creating a new one. I know that I could open the clip panel, scroll to the effect and drop the slice there, but this would be way faster when busking.
What do you think about it ?
Thanks !
Re: Appending Slices to an existing Slice Transform
I'd recommend to drop your additional slice to the slice list:
If you need to add the same slices to multiple clips, add the Slice transform to the layer instead.
