How do you control the wire video player from inside resolume.
I want to be able to send a stop, rewind when the source clip is disconnected.and not playing.
Currently when I stop the clip playing and restart playing it, the clip didn't stop.
Also how can you get autopilot to make the wire source loop inside resolume. Not from the video player loop function.
Thank you.
Video player restart.
tijnisfijn
- Team Resolume
Re: Video player restart.
I made you a little example, batch and tutorial in the Slack wire channel. I hope that helps you.
