Decks have option to have separate fx chains, and multiple fx presets
cat
Post by cat »
Another VDMX feature that I love was being able to preset FX chains (with midi shortcuts) It makes changing complex fx chains a breeze for changing work flows song by song. In resolume that would be great, but another workaround would be for each deck to have the option of different fx setups on layers, and maybe keep the old way as default with persistent fx chains. I tend to use decks a songs, and rarely want exactly the same setup for every song, the alternative is to have long chains and have to bypass the unwanted ones, but without presets fo that kind of thing, (or wire to have access to parameters, or osc send to arena) it makes it more complex
Re: Decks have option to have separate fx chains, and multiple fx presets
