Wire patch causes mayhem
mowgli
Post by mowgli »
I was working on a fairly simple patch, taking a MIDI CC which triggered an envelope, which in turn controlled the Amount on Bloom.
It was all working fine and as expected running in Wire, so I went to Arena and dragged the non-compiled patch: instant crash.
Now I can't even reopen the patch from Wire; again, it causes an instant crash. Everything appeared fine before adding Arena to the equation.
Any clues?
mowgli
Re: Wire patch causes mayhem
Post by mowgli »
CV THING MIDI envelope.wire
(17.47 KiB) Downloaded 1583 times
After opening a different Wire patch first, I can now open the troubled patch again...
mowgli
Post by mowgli »
I'm getting more confused by the second.
While attempting to troubleshoot, I've been simplifying the patch and testing in Arena. I'm down to texture in-bloom-texture out, and this crashes Arena.
I had just updated to the latest version of Arena
Still crashing with 7.23.2?
Can't see crash reports with your forum email, does the reporter not show up?
Maybe windows event logs have more info then?
mowgli
Post by mowgli »
I rebuilt the patch from scratch and now it works...
Baffled.
Well without the crash reports there is not much we can do.
The patch works fine for me.
mowgli
Post by mowgli »
I did submit the crash reports through arena
Ok, please contact us on mail@resolume.com from the same email address you used in the crash reporter form.
mowgli
Post by mowgli »
Zoltán wrote: Wed Sep 10, 2025 14:04 Still crashing with 7.23.2?
I'm confused about this. I use the same email on the forum and Arena.
I just sent another crash report, Arena is not opening now, I guess it's the Wire patch as it opened if doing so through a different comp.
Found one now in the back end, didn't make it to the inbox for some reason.
We'll see what we can do.
