Clips not triggering first time after changin decks
cat
Post by cat »
Just noticed this at 2 gigs this weekend, latest version, when changing decks the fist clip I click (mouse) after changing a deck fails to trigger, sometimes... It seems to happen more often when switching between a later deck (to the right) to a earlier (to the left) change deck click, clip in slot keeps playing, click again and it launches as expected. It was a a tight cues gig as well, so this was troublesome. Just check now and it is still doing it, occasionally, the best kind of bugs...
Re: Clips not triggering first time after changin decks
Did the deck load finish?
cat
Post by cat »
I'd hope so, there were only about 4 or 5 files in each deck, and I was switching during applause between songs. I've not seen this before this new version.
Using DXV clips?
with or without audio?
Stored on local SSD?
I've tried a similar scenario on windows, and it seems while the clips load, I can click the clips, and move the mouse away, and then the clips trigger once the deck load finished.
Does the mouse button work fine otherwise?
I had microswitches fail, like they were still clicking but the computer not registering the click.
cat
Post by cat »
DXV no alpha, no audio, on internal SSD, mouse is fine for every other interaction.
cat
Post by cat »
https://www.dropbox.com/scl/fi/k1xehgg8 ... vctyf&dl=0
Here is a demo video, the mouse over lay shows mouse clicks, and shows how long after a deck is switched I getting no trigger... images, wire source, and dxv videos
None of the videos in your screen recording were DXV.
Images are always slow to trigger, those can be converted to single frame DXV with Alley.
cat
Post by cat »
Well the point is, not delayed triggering, its not triggering at all, until a 2nd click, so its not a buffering thing, and once the deck has had a clip launched it, is fine until you change decks. And it affects wire sources as well. Fine if it has to load first, not fine if it doesn't load at all.
I've just checked through again and while it happens less often, it still happens with dxv, albeit 50fps, no alpha. Not bothering to load at all = bad. As I said I've never seen this until the last update, or maybe the one before
If you'd like to check the previous release, they are available form the bottom of the download page.
As it works fine for me, that would be the nex step I'd go for with troubleshooting.
Make sure to back up the Documents/Resolume Arena folder before reverting to an older release.
