OSC Output in shortcuts not visible
DannyLas
Post by DannyLas »
A newbee here,
just trying out Resolume Arena and following some online tutorials that output OSC but in the shortcuts OSC, the shortcut pane is empty. Is that because it is a trial version ?
I do have output enabled in OSC preferencies
I click shortcuts, then edit OSC, the shortcuts pane is empty
Re: OSC Output in shortcuts not visible
The OSC output all preset will be empty.
You can create shortcuts with a new preset you make.
To have them show up, make sure the Shortcuts panel is has enough height, best to move it to the right of the main window.
