Clips moved in layer, no idea why
Holm
Post by Holm »
Hello everyone,
Is there a way to move all clips in a layer by one column?
But not by selecting everything and then moving it.
My colleagues report that this happened, almost by accident.
Any ideas?
Many thanks,
Holm
Re: Clips moved in layer, no idea why
Right click on column, Insert before can do it
Holm
Post by Holm »
Hello Zoltán,
Thank you for your reply.
I think I described my problem not exactly enough.
Two layers were offset, content that should have been in the same column was no longer there. The content of the second layer was shifted by plus one.
Many thanks,
Holm
