PLEASE lock Video Router Input!!!!!!!!!!!!!!!!!!
manymanyhaha
Post by manymanyhaha »
This is going to drive me mad. Please, for the love all that is good in this universe, give us the ability to lock the Input in Video Routers.
Am I the only person that uses Video Routers? And multiple layers? Am I the only person that likes to add and subtract layers?
This is madness. I asked for this years ago and someone on here poopoo'd it but frankly, why would you just give us this ability and then just have Input roam when layers are added and subtracted? Makes absolutely no sense.
I use a lot of Video Routers, love them. But every time I forget about this silly limitation, I end up spending hours putting the Inputs back.
Please, lock the Inputs!
live stream of music catalog to Resolume youtube.com/@manymanyhaha/live
amsh
Re: PLEASE lock Video Router Input!!!!!!!!!!!!!!!!!!
Post by amsh »
Agreed! I just added a couple layers and now I have to go and edit every single slice transform to point them at the layer.
At the very least, Keep the input pointed to the same NAME.
If I rename a layer "LOGOS" and then I point my video router to input "LOGOS" layer, it should stay using whichever layer has the name "LOGOS" regardless of where it is in the stack.
Online
If you have two layers named LOGOS, which one should it point to then?
cat
Post by cat »
It doesn't matter as long it follows a pattern, the lowest numbered in layer, or the highest, as long as it is know thats fine, it the case of renaming you would presumable change the layer name (ie duplicate names) then rename the first one to swap the router. I'll be honest I use groups a lot, and add remove layers within the groups and assign the router to the group. This also goes for slices, I never assign a layer as all too often that will change as the project grows, but I often have groups of 1 layer, which is also a dumb way of working. Then you add a new group or have to move the order and that all goes tits up. Use Descriptive names, as a check box even would help. Personally I'd like a videorouter input to wire, especially if that could work with transitions, then you could dynamic mask layers/bumpers very flexibly.
Empyfree
Post by Empyfree »
Zoltán wrote: Sat Dec 13, 2025 12:14 If you have two layers named LOGOS, which one should it point to then?
I’d be very happy with a side effect of the proposed update being that you couldn’t have two layers with the same name. You’d have to have “logos 1” and “logos b”
It’s pretty common for layers/clips/things elsewhere to have to be unique.
I also love adding layers, and always forget to go through and fix all my routers that are now wrong!
KevinHughes
Post by KevinHughes »
+1
Really, all references to layers should be references to an internal layer ID that never changes, so when layers are renamed automatically or manually this kind of thing never happens. I cannot count the hours of time I've wasted trying to hunt down busted video router input layers because the content shifted when I added, deleted, or moved a layer in a totally different deck! And I would definitely have ruined shows if I didn't catch and fix this in time.
If you wonder what would happen when you import video routers from other compositions where the target layer ID does not exist, Avenue/Arena could try matching by layer name first. If no layer with that name exists, the input could then be set to "Layers Below" by default.
I personally think all references in a composition from one part of a composition to another part within the same composition should be handled the same way as well, like references to groups. It just makes things more robust, especially if one adds, inserts, duplicates, reorders, deletes, and renames cells, layers, groups, and columns a lot like I do.
manymanyhaha
My friend, if this is seriously the reason why you all are driving me mad, then goodness, there are many ways around this problem.
For one, you could have a pop-up that warns there is another layer with the same name that explains to the user why they might not want two layers called LOGOS.
Two, you could make layers have unique names under the hood, call them LOGOS1 and LOGOS2, for internal purposes. Lots of programs do this kind of thing.
Three, you could even make layers always have unique names. So if I created a second layer called LOGOS, the program would automatically make the second LOGOS1. Lots of programs do this kind of thing.
I'm sure there are many ways to solve this problem than having the Inputs just roam around. You all are creative and smart people. This is obviously a question of WILL, not MEANS. You have the means to solve this problem, easily.
Video Router are so amazing and awesome and you guys are killing the usefulness and possible creativity of this feature! I mean, do you use Photoshop or any other visual editing programs at all? Layers and layering are an integral feature of any visual editing program and that I don't want to add layers to my workfile because I will have to spend a half a day hunting down all of the places that adding that layer affects it is beyond RIDICULOUS!
Otherwise, appreciate you :)
Online
exactly, why I'm asking questions like that.
If you delete a layer which is referenced in a layer router by it's ID, does the layer router stop working then?
What happens in other decks with video routers referring to that layer that has been deleted?
manymanyhaha
Zoltán wrote: Mon Feb 02, 2026 10:32
Three suggestions: 1) The Video Router could go red like what happens when a plugin or FFGL is deleted that is referenced. 2) the input dropdown could go red, indicating no reference. 3) The input defaults back to Layers Below. If this one is selected, it would be super helpful if there was some way to indicate the input was changed.
I'm partial to 3, especially if there is an indication that Layer Below was defaulted to.
Same.
Thank you for listening.
KevinHughes
I like this idea - currently cells whose media content has been moved or lost for any reason show a button to relocate the media and a thin red outline. If a cell's clip has media containing effects or sources whose layer or group source has been lost for any reason, the cell could be outlined in red too, or made visually different in some way, like showing a broken link icon in it. Or maybe there's some link relocation process similar to media relocation? This would really help with troubleshooting.
When you import a deck into a composition, and references to specific layers or groups break, instead of choosing new defaults for the references, go through a link relocation process and/or highlight cells/clips with broken links visually - maybe this is a behavior that could be specified in settings?
