Memory leak 7.23.0-7.23.2
Magnitron
Post by Magnitron »
Good afternoon. I have a memory leak issue on one of my NUC13RNGI9 machines. The problem appears on versions 7.23 and is absent on versions 7.22. I have tried different combinations of reinstalls of resolume and different configurations of windows and drivers. I also tried not to use integrated graphics (the options are only enable and auto). I also note that I do not use Chinese adapters and capture cards. At the moment, the situation is as follows: in the task manager, the Resolume Arena application grows by 1 megabyte per second. I use the RGB color space. And honestly, I don't know what to try anymore.
Re: Memory leak 7.23.0-7.23.2
What's the dedicated GPU you have connected to the machines, and how?
Magnitron
Post by Magnitron »
Nvidia QUADRO RTX A5000. in the nvidia control panel, I specified the process and which graphics adapter to use.
PCI-E slot.
Try the 550 version nvidia driver, or one before that
Magnitron
Post by Magnitron »
It's working. Thank you very much! I installed the driver version 553.62 And the RAM leak stopped. I note that the Arena did not launch at all on version 545. Should I worry that version 553 won't be supported with future updates?
Christoph
Post by Christoph »
We reported that leak to Nvidia and hope it will be fixed in a future graphics driver update.
In the meantime, if you want to use the latest driver, you can start Arena in debug context, then it does not leak. For this you have to launch Arena from the command line with
Code: Select all
.\Arena.exe --debug-gl
tschnz
Post by tschnz »
I just got word from NVIDIA that they can reproduce the bug on their side and will start working on a fix, so fingers crossed it makes it into the next driver update :)
Roses are red, the economy dire,
here's free patches for Resolume Wire
www.github.com/tschnz/Resolume-Wire-Patches
