Virtual network adapter connection
joaquinundo
Post by joaquinundo »
Hey,
Trying to get Arena (7.23.1) working with Chamsys and Capture visualizer simultaneously and using unicast. Running Arena and Capture on the same laptop, MBP M1.
Arena and Capture work fine simultaneously when broadcasting, but I have to use unicast and then Arena only receives values from console when i turn Capture off, this happens probably since they are sharing the same IP address (2.0.0.99). So, Arena and Capture probably need their own separate IP addresses. Tried making a virtual network adapter with IP 2.0.0.98 but it does not show up in Arena, Preferences-> DMX -> Network adapter so i cant connect to it.
Any ideas how to get this working?
Re: Virtual network adapter connection
Having two applications listen on the same port usually doesn't work.
Virtual network devices are not supported in Arena.
Maybe they are in the other app?
Otherwise, adding another physical network interface to the machine should be a good solution.
