So I have lots of crashes with Wire...
When patching after a while adding a new node, adding or removing connections, deleting a node, even opening examples or tutorials Wire crashed. I have submitted multiple crash reports, trying to give descriptions of what happened. It has been very frustrating, I couldn't get any work done.
However after days of trial and error I may have found the problem. Nvidia driver. I work on a thinkpad with a rtx 3000 in it, with the freshest driver, at time of writing this 581.8, Wire crashes as described. When downgrading back to 527.27 everyhing works fine.
The only problem is that I use Nvidia broadcast, which requires driver 572.61 or higher.
Am I missing something? Is there a way I can patch in Wire and have nvidia broadcast? Do we know what changed in the drivers that can cause this? Is there a driver version that works?
Nvidia driver compability
Re: Nvidia driver compability
We were working on some crashes with Nvidia Quadro cards and the latest drivers, and those should be fixed with Resolume 7.24 once this is ready for release.
Have you tried 572.61, does this one crash as well for you?
