How do you trigger the effects in resolum? with which device?
i read here about oxygen8 or xboard25- do they work like the BCR? do they have presets so each time i trigger different effect?
i got more then 100 effects in resolum- can i use the oxygen to trigger them all or do i need a bigger one like the xboard 49?
thanks
						controling effects
Need help here...
1 BCR2000 to control the interface of resolum and I'm looking for midi keyboard to control the effects. i need your advise if i can program oxygen 8 so each time i trigger different effect?
if you use some of the freeframe effects then you got more then 100 effects...
