the solid color fragment is always red
Kirill_promotograf
On the timeline, the solid color fragments are marked in red, regardless of the color that is displayed on the screen. Is it possible to match the color of the square on the timeline with the color that is displayed on the screen?
tijnisfijn
- Team Resolume
Re: the solid color fragment is always red
Just select the clip and push command shift T (Mac) or control shift T (PC). You can also right click on the clip and select thumbnail > update thumbnail.
Kirill_promotograf
tijnisfijn wrote: Sat Nov 22, 2025 00:54 Just select the clip and push command shift T (Mac) or control shift T (PC). You can also right click on the clip and select thumbnail > update thumbnail.
Thanks, friend! It's amazing! I hug you!))
