Realtime 3d render in resolume !
Andres^C4^
Post by Andres^C4^ »
hi all, im starting to use VVVV to create 3d texts and in the future maybe more things ( im a complete noob at vvvv ) . I use this with resolume, using the Capture Screen funcion... but i have some strange problems... when i use this combo on my desktop computer, it works, but on the notebook sometimes works and sometime not,,, on resolume i see vvvv screen and paches but without the video, i only see a gray box,,, but sometimes it works,,, why skips the content of the window?
there is another way to set the capture screen opcion in resolume to leave it on a place without using the mouse ? i mean i want to use my mouse without moving the capture screen imput.
is possible to resolume creator to conect thouse 2 softwares in a better way ? like the coneccion between 2 compures on resolume, it should be a way to use vvvv output as another computer with resolune?
vvvv supports hundreds of different imputs and outputs,,, and its free... it would be an EXELENT improve to next version of resolume... wi will have 3d render in resolume for free ...
edwin
Post by edwin »
Hi Andres,
Check out the the Video Streaming Plugins on bigfug.com.
These plugins enable you to stream video between Freeframe enabled applications. VVVV has freeframe support if i'm not mistaken.
http://www.bigfug.com/index.php?/pages/freeframe.html
Cheers,
Edwin
Andres^C4^
Cheers,
Edwin
hey thnks for the help. i´m trying to do it but i cant figure it out
i installed the freeframe plugin on resolume, it seems to load it without any problem like any other freeframe plug in. you have to aply it to a video.
i think the problmes is on vvvv
i put the dll in /freeframe and in /modules/multiplescreen
so i can "load" the .dll as a patch. i already edited the .cgf file and set the same values on resolume freeframe plugin, but it don work.... so i´m trying to doit with 2 vvvv with the send and the receive modules, but i don have any result. do you have any idea of that im doing wronk ?
http://200.68.95.201/rosarioe/c4/nodos.jpg
is possible to set vvvv as a vidnetserver for resolume ? this would be the best option i think
tnks for the help, keep working :)
[Edited on 23-7-2007 by Andres^C4^]
Great preset Andres! ;-)
Andres^C4^
come on bart dont be so bad, im a complet newbie here :P
that preset is to test the plugin ( still dont work )
twhat i want to mix in resolume is this preset
http://www.vjc4.com.ar/nodos001.jpg
http://www.vjc4.com.ar/nodos002.jpg
http://www.vjc4.com.ar/nodos006.jpg
http://www.vjc4.com.ar/nodos007.jpg
http://www.vjc4.com.ar/nodos008.jpg
http://www.vjc4.com.ar/nodos009.jpg
its my second day with vvvv,,,its very simplem,, but with live video its a very cool effect. it would be greate to integrate this with resolume
