FEATURE REQUEST: Wild cards or index for OSC messages for effects
VJPanda
Post by VJPanda »
I am creating a controller in TouchOSC and so far am pretty happy with how it is turning out.
One thing I want to include is a "kill switch" for when effects pile up and get out of hand.
I know I can address effects directly
Code: Select all
\composition\layers\3\video\effects\goo\bypass\
but hard coding something flexible like effects is never a good idea.
Thanks to a Redditor I have discovered that
Code: Select all
\composition\layers\*\video\effects\goo\bypass\
works to bypass Goo on all layers. This is a good thing.
But unfortunately using the same logic with a wild card for effects doesn't work
Code: Select all
\composition\layers\3\video\effects\*\bypass\
Alternatively being able to address effects by index and looping would be great e.g.
Code: Select all
string.format("/composition/layers/3/video/effects/%d/bypassed", effectNum)
Ideally, the ultimate kill switch would be
Code: Select all
\composition\layers\*\video\effects\*\bypass\
- to be used with caution :shock:
