My wishlist
johnwhy
My wishlist
Post by johnwhy »
Hello guys,
my wishlist:
1. drag and drop to re-order clips in cells
2. render function to render an fx to a clip (as opposed to record)
3. in record the latest chosen video codec is remembered
4. the ability to save FX settings to a named file pre-set
5. it would be good to have an output bus before the main output
(increasing the scope of the fx)
6. the ability to record keystrokes (to prepare mini/parts of mixes)
7. resize and place the video anywhere on the screen
8. the ability to import and play/pause audio through the interface (as a guide when setting up clips)
johnwhy
We have already built 1 and 7 so you can expect those in the next major version. What exactly do you mean in point 5: it would be good to have an output bus before the main output (increasing the scope of the fx) ?
johnwhy
Post by johnwhy »
thanks for the reply, version 3 sounds tasty already...
by an extra bus i mean one more level of fx - so you would have clip FX, then you could direct one, two or all of the screens to a bus effect then finally the global fx...
i think it would be really good if you could just render a clip fx
as it would free up resources...
johnwhy
