Use Bank select on AKAI APC40 MKII like ABLETON LIVE TO NAVIGATE and select the clips in the deck
davide93
Post by davide93 »
Hi there, I've started using an akai APC 40 MKII controller and I like the way it can control resolume. Just it allows to control only 8 columns in a deck. I would really appreciate if it could be mapped to be used as it works in Ableton Live so pressing the right button it should select and allow you to handle the next 8 columns in the same deck and pressing the left button it should select and allow you to handle the previous 8 columns in the same deck.
At the moment the workaround is to create many decks with 8 columns each. In my project there are more than 100 columns and I don't like the idea of splitting the composition into so many decks.
I hope this feature will be implemented with the next version of Resolume.
Best,
Davide
