SMPTE or not to SMPTE…
Amritus
Post by Amritus »
Is it possible to have SMPTE on envelopes instead of Timeline, basic or all the other types assigneable?
I want my envelopes to follow along with SMPTE, not just trigger a start of an envelope on a timeline.
Is there anyway to link envelopes so that one envelope acts as a master and everything linked to it follows the master envelope and all changes is thus always the same in all envelopes...?
Perhaps even allow all the settings from an envelope and timeline be linked so that one setting can be used as a master controller for many other linked envelopes and timelines.
Re: SMPTE or not to SMPTE…
set param to clip position
Amritus
Post by Amritus »
Zoltán wrote: Tue Jan 27, 2026 15:33 set param to clip position
Yeah, I just realised it was the right setting I was looking for.
Though it does work for correct clip position, I don't know if the envelope I det for it will be as exact as I want it because the envelope is in % and not frames. If using SMPTE on any envelope, I'd love to have it use the actual time the timecode for setting nodes on the envelopes.
With %, it's sometimes correct, sometimes slightly off.
