Change fps Resolume Alley
VjLuper
Post by VjLuper »
Hi guys! I need to export a DXV file from a PNG sequence. I'm trying to use Alley for the first time, and looks like there is no way to change the fps from 30 to 25.
I mean, when I import the directory with all the PNGs Alley set as default 30 FPS. I want to change to 25
How can I do it?
thanks
Nic
Christoph
Re: Change fps Resolume Alley
Post by Christoph »
What version of Resolume do you have installed?
VjLuper wrote: Wed Jan 28, 2026 15:58 How can I do it?
In the bottom right there is the FPS value, in your shot it's set to 30, but it also looks like it's selected.
If you change that to 25 does that not work?
