Default video sources presets
mowgli
Post by mowgli »
Is there a list somewhere or someway to discern which video sources presets are the default ones shipped with Resolume and which ones I've added myself?
Re: Default video sources presets
You can find the original factory preset files in the application folder/Default/presets
These are copied to the Documents/Resolume Arena folder on clean install, those are loaded.
When you overwrite them, those copies are the ones modified.
There is no distinction in the UI to see which preset is factory, and which you saved.
mowgli
Post by mowgli »
Great, thanks.
