I just found another dashboard related bug.
I assigned a parameter called Smudge to Link 7 which had nothing else assigned to it and the automatic label that appeared reads WobbleV.
Not a show stopper, I can easily change it but it is bizarre.
I'm pretty sure I've encountered this before.
Dashboard label bug
OnlineZoltán
- Team Resolume
Re: Dashboard label bug
how did you do the assignment?
When setting the param to dashboard via the cogwheel menu, it takes the first dashboard dial as selected
I dragged the parameter onto the relevant link, which had nothing assigned.
WobbleV is not even a parameter name for anything on that clip.
Can you recreate this with the same clip or was this a one-time glitch?
It's the first time I mention it, but it's happened a few times in the past. The first time about 3 years ago I think.
