Convert a DVD to .MOV
Stivo
Post by Stivo »
Just a little Question,
Since i have my new MacBook Pro. I want to use my visuals on both Windows and Mac.
I want to encode my movies in .MOV format.
Most of thim are .AVI but does anybody knows a good program, witch can convert thim batch, and split thim.
With a good codec like these files:
http://www.resolume.com/footage/digital ... ?fp_id=415
messhead
Post by messhead »
I use Xilsoft stuff, VERY GOOD!
I hear good things about Handbrake to convert a DVD to MOV
http://handbrake.m0k.org/
Stivo
Post by Stivo »
I used thim before, but th quality is poor.
Witch program / codec do you use..?
Stivo
Post by Stivo »
It probably will be good, but Resolume can't play thim.
Im testing it now, i really want files with a good Quality and a .MOV extension.
[Edited on 23-9-2007 by Stivo]
messhead
Post by messhead »
Never actually used the DVD to MOV so actually cant say about that one so you may be right, MP4-AVI, MOV-AVI are the ones i mainly use
Stivo
Post by Stivo »
Well, actually the case is:
I want to heb good quality files, with can be used on mulitplatform system like:
OSX / Windows and can be used with multiple programs, like Resolume.
.MOV is the best i think.
messhead
Post by messhead »
I hate .mov files haha. Same as quicktime. Rubbish. Luckily i dont use Mac so i dont have to put up with them. Simple basic AVI for me all the time
