OSC message order on clip change in same layer
Cunabula
Post by Cunabula »
Hello,
Possibly very niche problem but here goes:
Is it possible to change the order that clip connected messages are sent when changing clips in a layer? I'm asking because what I actually want to be able to tell is whether a layer is currently playing a clip or not and I can't see a layer level message for that information
From what I can see, OSC messages regarding clip state are sent in numerical order by clip
So changing from say Layer 1, Clip 1 to Layer 1, Clip 2 the OSC messages sent out are:
/composition/layers/1/clips/1/connected : 1
/composition/layers/1/clips/2/connected : 3
This is great, any most recent message from a layer with an argument > 2, there's a clip playing in that layer.
The problem is if you want to go to a lower numbered clip then the messages on transition are
/composition/layers/1/clips/1/connected : 3
/composition/layers/1/clips/2/connected : 1
It would be very helpful if they were instead always in the order:
Clip Stopping
Clip Starting
Then you'd have the current state of the layer without creating a new type of OSC message or having do anything fiddly with how you're handling the messages externally, which I expect I'm about to do.
Anyway, said it would be a bit niche, but it would be helpful :)
Re: OSC message order on clip change in same layer
You can have two clips playing in a layer, during a transition. A clip which is exiting, would send the stop after the start of the new clip.
/connected address has 5 states,
0= empty slot,
1=clip present, not connected or previewed
2=clip previewed, but not connected
3=connected, but not previewed,
4=clip previewed and connected.
A clip placed in a layer can play in a different layer, with free layer or active layer target, or by droppign it to a specific layer, so you can have multiple clips giving >2
You can do a query like /composition/layers/*/clips/*/connected "?" to get all clip states
Cunabula
Post by Cunabula »
Thanks for getting back to me Zoltan, that makes perfect sense and I just hadn't considered it even though I do use transitions. Sometimes I'm super clever.
I did get round it pretty easily with a script I'm working on so it wasn't that big a deal in any case.
