flightcase recomendations?
coolhandloop
Post by coolhandloop »
allo was jus wondering what people use to carry around v4 , the annoying thing about aquiring new bits of hardware is having to look after them ..,can anybody recomend a good bag/flightcase for use with v4?. and while were at it can anybody recomend a decent laptop bag , onethat can hold bit extra,
nice one
charlie
gdlt
Post by gdlt »
I would look for a DJ vinyl bag. you can place your laptop and some hardware in it (video mixer and/or controller).
Danger
Post by Danger »
i use some tools cases for my v4 and my midi controllers...they are realy cheape and after you put some sponge your material can take some strong "kick's"
here an example
[Edited on 4-10-2007 by Danger]
TZ0013 (4).jpg (30.21 KiB) Viewed 8080 times
juba
Post by juba »
i would go for a sturdy flightcase, it's always possible that some tech guy or random drunk steps/stacks/kicks your gear. better have it in a strong case (also handy when setting up)
i use a flightcase for laptops (custom build back in the days i guess)
- you can take of the lid and put it under the other part
- modded a part of an old suitcase in the lid to store cables and convertor parts
- used some cable to secure the V4 and attached a LCD-tv next to it
- i also added a powersocket
