Midi mapping play pause button for a timeline parameter
cat
Post by cat »
I'd like 1 button to play and pause (or stop and restart) the timeline controlling a parameter. Is there anyway to do that, mapping it to play or pause just makes it toggle forwards and backwards.
I've mapped the button to speed now, which works, but why bother with a pause if you cant map it and make it do anything?
And it doesnt seem to work on another parameters speed on the same effect slot at the same time...Again, I ask you to go and look at vdmx and numberfx, unless this is a bug and it should work?
\ok bug, it works after a restart
