Equaliser
joostnl
Equaliser
Post by joostnl »
Dear users
I have read the manual serveral times..
But i can't find nothing about my problem.
I know that in Arkaos there is a effect called 'wave form' I call it the 'Equaliser' (see the attachment for more details)
Is this possible in Resolume?
I see at my audio input that the bars move.. Is there a standard effect for? or Must I download a plugin?
Can someone explain this step by step?
Thnx!
Joost (sorry for my bad english)
nwonknu
Post by nwonknu »
http://www.bigfug.com/uploads/fugFreeFrame.1.11.0.zip
There's plugin ''fugScope'' in the pack
cheers
joostnl
Post by joostnl »
Thnx mate!
Basic
Post by Basic »
thanks for the Link as well :)
RanaRapaz
Re: Equaliser
Post by RanaRapaz »
i cant see those plugins in Resolume 4.1.2, the path is ok but i can´t see nothing in the sources or effect folder.
Do you know what can i do?
Basic
Re: Equaliser
Post by Basic »
RanaRapaz wrote:Hi,
These plugins are an older standard so they won't work natively in Res 4.1.2
I'm not sure if you can port them somehow - I can't think presently. Maybes have a quick search and see what it comes up with.
