After updating to Resolume Arena 7.25.1, all MIDI mappings assigned to “This Clip” in my composition have disappeared. Even when I try to reassign them, they are immediately lost again.
I believe this is a bug—could you please look into it?
Thank you.
The MIDI settings configured in this clip are being lost.
Re: The MIDI settings configured in this clip are being lost.
I was able to recover the lost MIDI mappings (target: “This Clip”) by rolling back using the workaround below.
Until this bug is fixed, you may need to use this workaround if you want to use MIDI mappings with target: “This Clip.”
1. Back up the Resolume Arena folder in your Documents folder.
2. Uninstall Resolume Arena.
3. Download and install Resolume Arena 7.24.3 from the download page.
4. Restore the folder you backed up in step 1.
Can you send us the shortcut preset and composition you use?
Thanks for taking a look at my post!
No problem — I’ve attached the composition file and the MIDI shortcut XML I’m using.
Thanks,
I removed the link from the post
ok found them, made a ticket.
