Lost midi focus on clip when switch deck
When I switch deck, I lost midi focus on the selected clip. I can manually change parameters in clip panel, but midi doesn't respond anymore (midi shortcut is on "selected clip" mode). I have to go to its deck and re-select it in order to make midi work again on it. On old versions of Resolume it happened from now and them, but on recent versions it happens randomly. I cloudn't find a workaround for this. I'm very used to use midi to change parameters of the selected clip on "clip" panel (pos x, pos y, scale...), and now I have to do it manually.
Re: Lost midi focus on clip when switch deck
When you switch decks, your selected clip will be cleared and unloaded, so you can't access it any more direcly.
Clips from other decks playing in layers can be selected and interacted with, and it indeed looks like they could do selected clip midi shortcuts in earlier versions.
Not sure when that changed.
I'll make a ticket to get this back.
Any changes made to these clips from other decks won't be applied to the original clip in the deck though from a different deck. Something to keep in mind.
