Loop Mode for smoother Loops
movebandit
Post by movebandit »
What about another Loop Mode ? you got already Loop and Bounce but especially for video loops a fading loop would be perfect.The last and the First frames of the File should be faded together (Perhaps with a selectable ammount of frames). This would result in much smoother Videoloops without that hard cuts.
Eh ?
gdlt
Post by gdlt »
I was thinking exactly the same last weekend somekind of function that you can delete the first or last frame. so don't have to do that in your editting program annymore, for example when you make a 360 rotation in a movieclip, and the first and last frame are the same....
movebandit
Thats not what I thought about. You can do this by Setting the in and out points. Id like to have a Crossfade between the first and last frames.
So when you ve got a short sequence thats not loopable and play it with that crossfade, youll get a smoother transition between start and end.
gdlt
Post by gdlt »
o ok that would be a nice function too.
I know you can set the in and out points but not with a 1 frame step.
subset
Re: Loop Mode for smoother Loops
Post by subset »
I would like to see this feature too!
Christoph
Post by Christoph »
