Matrox dual/trippel head2go
keessie
Post by keessie »
hi guys does anybody knows if thease things are allready compatible with resolume??
i found some old topics only that gives me not the information i need.
thnx
keessie
Re: Matrox dual/trippel head2go
Post by keessie »
i allready found an answer for this problem, the current version of resolume doesn't support this box. but the guys from resolume are bussy with an new version and then it will work
miau
Post by miau »
keessie wrote:i allready found an answer for this problem, the current version of resolume doesn't support this box. but the guys from resolume are bussy with an new version and then it will work
I believe you're wrong! Check this thread: http://www.resolume.com/forum/viewtopic.php?f=7&t=3174
keessie
Post by keessie »
if iam wrong than the guys from resolume are wrong i emailt those guys
The method described here is a hack and might not work for everybody, but give it a go and let us know if it works for you.
miau
Post by miau »
Hey, if you don't want a solution just don't try it or don't ask for one.......
Vj Screen - Proception Visuals
Myspace: http://www.myspace.com/proceptionvj
Core2Duo 7200 - Nvidia 7600 GO / P4 2.66 - Ati 9600m / WD Mybook SE Edition 500Gb
Panasonic WJ-AVE5 / 2xEdirol PCR-M30 / Behringer BCR200
keessie
Post by keessie »
o no i was planning to buy such a thing only i'd rather wait until it works for sure before i spend my money and it don't work
miau
Post by miau »
keessie wrote:o no i was planning to buy such a thing only i'd rather wait until it works for sure before i spend my money and it don't work
I just provided a solution (a hack, like Bart said) I didn't force you to buy anything!!! You just had to read the thread and apply or not to your situation. I didn't call anyone a liar nor I judge anyone.
Best regards!
