window
Fongaboo_
Post by Fongaboo_ »
is there any way to get the control screen to operate in a regular window? it makes it very difficult to work with other programs while Resolume's control screen is taking up the whole screen. if not, can this be added to future versions?
FONG
there is no way to run it in a 'normal' window ie not fullscreen ... we always use the ALT + TAB function to switch between programs when running resolume.
Fongaboo_
Post by Fongaboo_ »
and why doesn't it remember monitor settings the next time you open it?
there is room for improvement ... we know ... but it is not a priority @ the moment ... we R working on implementing the freeframe effects plugin system.
