Using Korg Kaoss Pad 2 with resolume
				VJ Rick floyd
I have a Korg Kaoss Pad 2 and was wondering if it is possible to use it with resolume? does it support it?
						Re: Using Korg Kaoss Pad 2 with resolume
What do you want to use it for?
if you just want to use the midi x/y pad, and buttons. easy. plug it into your computer using MIDI, and then assign the x/y pad to a control in resolume.
