Confused About the Resolume Store
craftycurate
Post by craftycurate »
I recently bought an R2.41 license.
However, when I log on to the store, there is no information under "My Account". All it says is "thanks for logging in."
Is there supposed to be some information here e.g. serial numbers?
Richard
VjSky
Re: Confused About the Resolume Store
Post by VjSky »
You should have got the serial by email, it is sometimes hard to find, just reat the email carefully
craftycurate
VjSky wrote:You should have got the serial by email, it is sometimes hard to find, just reat the email carefully
Thanks ... I did get the email with the serials. It's just that the online account doesn't appear to hold any information - what purpose is there in logging on?
When you buy footage or plugins you need to login to your account to download the files.
I've been trying to find time to update the account pages in the shop so it will show all the past orders with invoices and Resolume serials.
craftycurate
bart wrote:When you buy footage or plugins you need to login to your account to download the files.
Great, thanks. No rush for that one with R3 on the way :)
