Hi, it seems as if I have 2 serious problems with this beta version.
1. I cannot open any of the submenu's at the top of the screen.
For example: I can click on "composition", but then nothing happens when I try to open/save/change beat snap/preferences... Therefore I can't get to enter my serial code. This is the same for all other menu's at the top. I can see them all, but I can't change or enter a thing.
2. I can trigger the demo clips that autoload, I hear the audio, but the output monitor only displays a "checkerboard" pattern. Same thing with the preview monitor. I tried loading up one of my own jpg stills and that I could see, but when I tried loading up some of my movies it didn't work (apple photo jpeg codec). And then, after trying different clips... Resolume crashed.
My setup:
Apple G5 PPC dual 2,3Ghz (late 2005), 7,5 gig ram, 2x Nvidia GeForce 6600
Macosx 10.4.11
Log file in attachment...
Hope everything's gets fixed real soon...
Not working on PPC G5 and crashing
- Attachments
- Resolume Avenue 3 log kopie.txt.zip
- (3.23 KiB) Downloaded 620 times
Re: Not working on PPC G5 and crashing
Is there somebody out there with the same setup as mine? G5 PPC dual 2,3 with macosx 10.4.11
Can you get the program to run normally or do you encounter the same problems as I do?
Let me know...
Greetz,
NLS
EDIT: I tried it on my girlfriends imac intel (10.4.11) and she has no problems. So I guess it might be a PPC problem... Would like to hear from you guys...
Let me know...
Greetz,
NLS
Yes have exactly the same problem.
No video output, No access to top menu.
Im also only getting audio playing and none of my own clips willplay.
Computer is extremely sluugish when resolume is running but activity monitor is not showing to much strain.
On a PowerMac G5 1.8 dual 4gb memory GeForce FX5200
