1) When reloading a saved composition, some direct key mappings lost (F1-F3), but some were retained (<Alt-F1> - <Alt-F3>)
2) Decks do not reload properly if one of them was empty. I had a composition with 3 decks PI1-PI3, and PI3 had no clips, and the "Composition" tab correctly listed the first two decks (PI1, PI2), but when loaded, decks PI2 and PI3 appeared.
BUGS
craftycurate
BUGS
Re: BUGS
I also experienced the "empty decks" issue.
Saved the composition, and no matter how many different ways I saved it, saving the orig. file, save as etc. I could never get it to remember more than 2 decks at a time.
I had to manually reload them every time I wanted to use the composition. It did however save the exact number of decks it called "empty" - which I had to delete - and while trying to delete these "empty" decks from my comp, the program crashed about 4 out of 5 times.
Anyone else?
Anyone else?
Re: BUGS
I've also experienced the two deck issues as described above.
I've also a strange behaviour which do not allow me to load more than 75 loops for a deck.
No matter if i load 74 loops in one layer and only 1 in the second layer, or 25 in first layer 25 in second layer and 25 in the third layer, the total possible amount of loops for a deck is 75. Resolume allow me to drag and drop more than 75 loops in a deck but the thumbnail and the loop won't work.
Is this a know issue?
Win XP SP3 - Coreduo T2300 - Nvidia Geforce go7600 - 2048 MB Ram
Re: BUGS
We found some info about the 75 max .avi clips.
Apparently we can only have 75 avi files open at the same time.
http://whorld.blogspot.com/2006/05/pre- ... video.html
I'm making a workaround for this.
