Startup questions - loading decks and voice
gpvillamil
Post by gpvillamil »
How to disable autoloading of footage on startup? Resolume always loads the demo footage. Conversely, how to set a user-created deck to auto-load?
How to disable the "voice" on startup? I can see situations where Resolume would start up connected to a PA, and the voice is disturbing...
Aside from this, am really liking it. Feels like an Ableton for video...
GeeEs
Re: Startup questions - loading decks and voice
Post by GeeEs »
1) When you clear the demo composition and save it as [whatever] it wil load that composition when you start the program again.
2) When you register your copy of Resolume 3, the voice and watermark are gone ;).
gpvillamil
So it always loads the last saved composition?
GeeEs wrote:1) When you clear the demo composition and save it as [whatever] it wil load that composition when you start the program again.
GeeEs
Post by GeeEs »
as far as i can see at this moment.. yes. But I'm also just a new user ;)
But if you keep in mind that a composition consists out of several decks it's no problem imho.
gpvillamil wrote:Resolume always loads the demo footage. Conversely, how to set a user-created deck to auto-load?
Avenue always loads the last opened composition on startup.
gpvillamil wrote:How to disable the "voice" on startup?
Buy a serial in the shop ;-)
gpvillamil
bart wrote:Buy a serial in the shop ;-)
I bought 2, months ago! (And the voice is gone, thanks!)
