If I am in 3 Panel Layout and switch a layer to BPM-Sync then the playmode lies under the beat number and I cannot access the loop button.
flo
Bug - 3 Panel Layout
- Attachments
- beat over clip loop.png (4.63 KiB) Viewed 4028 times
Re: Bug - 3 Panel Layout
This is not a bug, you simply do have not enought screen real-estate to show the 3 Panel Layout. Switch to the 2 panel layout and you should be fine.
ok, that sounds quite logical
