the message shows this: your videocard has unsufficient specs ti run this application!
I have an ATI HD 2600 I gh ram...
Never had a problem with Resolume 2.41 !!!!!!!!!!!!
Any suggestions????
thanks in advance!!!!!!!!!!!!!!!!!!!
ikyut
Video engine Couldnpt start!!!!!!!!!!
Re: Video engine Couldnpt start!!!!!!!!!!
works fine for me with this graphics card. will check which drivers i have and let you know.
i have driver version 8.413.3.0
the date on it is 29/09/2007
my catalyst control centre version is 2007.0920.2342.40548
i hope this helps and that i havnt just spouted random rubbish at you
Thanks a lot bro I will check the drivers, an try it, the rare thing that happpend to me is that I install the Avenue on my windows vista partition and works perfect....
thanks a lot for answering my question...
havnt tried it under vista, im running it with XP Pro sp2.
I try today, on vista, and everything works perfect.. the fullscreen output, the midi mapping.... I control it by the BCR 2000, and makes effects on the audio with the Kaoss pad 3... and trigger samples... also...
These days I will work on the Xp pro SP2 to see if I can solve the problem....
I will write with the results....
I put the latest drivers and nothing happend,
the point is i can`t make the midi devices work on vista!!!!
any advice?
any advice?
